nitrous aux
jna7i
nitrous aux
Post by jna7i »
hii..
info's posted under
i have a 2000 honda civic si with forced induction b16a engine equipped with a hondata s300 chipped on a p91 ecu that i purchased nd install it two years ago,,,so im running a stage 1 snow performance water/methanol system on the car and i test system monthes ago nd it was working great,,,i tried to start the system about two weeks ago at dyno session i tried to test system b4 dyno nd it was working when i tic on the the invert output icon but it wasent working when i reach activation point(rpm) but after a few runs it started to work all the sudden i finished dyno everything was great i brought a good numbers 420whp nd drove it couple times after that nd everything was great...so a week after that it stoped working all sudden,,i thot it maight be the relay between system nd ecu i test it nd it was good i cheacked meth pump nd it was working i brought the laptop nd test it nd it was working as well but the problem is that its not working when should at the activation point(rpm)...
nitrous/aux1
function generic output
input disabled
output a15 acc(air conditioning clutch) not invert output
nitrous/aux2
input always on no tics in boxes
output a15 acc no invert output
activation point:
5514rpm
for more info pleas tell me how to post the calibration.
jna7i
Re: nitrous aux
Post by jna7i »
hondata serial# s300-13347
Re: nitrous aux
