AEM Wideband into FPM values
08si
Post by 08si »
Hello,
I am wanting to use my AEM Wideband (30-4100) for datalogging via FP. I will be using the A44 ECT2 Pin out as my ELD will be used for your TC system.
Can you please confirm what if any values I would have to input into Voltage cells and Lambda (:1) cells?
http://www.aemelectronics.com/Images/Pr ... 0-4100.pdf
Also, I have just received my TC pins from you - I noticed there are two sets. If I use one set for my TC install can I use the other for my AEM Wideband without having to request these again?
Thank you
Re: AEM Wideband into FPM values
You must use the conversion chart on page 5 of the instructions from AEM.
Yes you can use those pins.
08si
Post by 08si »
Thanks!
So just so I am clear. Would I input the following?
0V / 4.99V
Lamda (:1)10 / 19.98
Wideband votlage input as ECT2? I intend to use ECT2/ pin A44
and disable ECT2 under MISC settings?
That is correct.
08si
Post by 08si »
Thank you for the quick response, you are always very helpful :)
08si
Post by 08si »
Another question came to mind and I couldn't find an answer.
When reviewing a datalog with the WB hooked up to the ECU, which value or sensor will depict the data it has recorded in FPM? Will it replace the current AFR or AFR corrected values?
AF in the sensor window will show the aftermarket wideband data.
08si
Post by 08si »
Thanks, so no need to use the AF corrected anymore right?
correct
08si
Post by 08si »
Thanks, is there a way I can still monitor what the primary o2 is doing for comparison?
Sorry, the aftermarket wideband will be displayed as Wide in the sensor list and the oem wideband will still be displayed as AF.
08si
Post by 08si »
No worries, Ok, thanks for the clarification.
08si
Post by 08si »
So I am having an issue with the displayed sensor data for the Wideband. It pretty much just stays at or within a couple tenths of 10.50..this is with the primary o2 all over the map. Any idea on what would cause this?
Use a multimeter to check the voltage coming from the AEM analog output.
