ECU to fit 94 integra VTI-R
elitem4gic
Post by elitem4gic »
hi there, I just recently bought a 94 integra VTI-R and have been having problems with the variable valve timing and VTEC which I found to be being caused by the ECU which has knackered itself. im struggling to find an ECU for my model and year (37820-p72-q01 AP) (B18C2 DC2). I don't no very much at all about Honda engines but I if anybody could point me in the right direction as to what other ECU`s could fit my car it would be greatly appreciated.
Re: ECU to fit 94 integra VTI-R
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want (http://www.hondata.com/sproducts.html). I would recommend the s300.
