Fuel tables absent???
Stez
Post by Stez »
Hello, im pretty new to Flash Pro, i have Civic Type R 2007 Euro. I opened stock equivalent calibration and could be able to see the main fuel tables for Low and High points, the only thing this calibration has is WOT afr low and WOT afr Hight... is this normal? or i should turn on something to see the Fuel tables ? Should we tune fuel only with WOT afr tables??? or how can we tune fuel?
Re: Fuel tables absent???
That is an AFM based calibration and dows not have regualar fuel tables. IF you want to tune via map you will have ot use one of the race based calibraitons.
Stez
Post by Stez »
Spunkster wrote:That is an AFM based calibration and dows not have regualar fuel tables. IF you want to tune via map you will have ot use one of the race based calibraitons.
We have full exhast + CAI + TODA cams on the car and need to tune it, will this WOT afr tune will be anough to tune fuel or we will need to use MAP calibration to tune the car in our case?
You should use a race calibration to tune this.
Stez
Post by Stez »
Ok thanks !!
nunoctr
Post by nunoctr »
Spunkster wrote:You should use a race calibration to tune this.
sorry but no.
He should use AFM calibration with map fuel tables.
Open an AFM tune, open "fuel" and the check the "use speed/density (MAP) fuel tables"
uncheck "AFM enable".
Then tune the fuel with MAP fuel tables.
I'm sorry What I meant to say was you will need to enable MAP based tuning like a Race calibration in one of the calibrations with RSP in the name.
