B21 stays open with 3.3.0
Nineteendc5
Post by Nineteendc5 »
I am having the same issue with the new 3.3.0
Tried it on 2 seperate laptops with 3.3.0, but i tried uploading the map on a laptop with 3.2.4 and it works perfectly. I need a fix asap!
Re: B21 stays open with 3.3.0
Please post your calibration, as I cannot reproduce a problem here.
Nineteendc5
Spunkster wrote:Please post your calibration, as I cannot reproduce a problem here.
Ok i'll post it today
Nineteendc5
here is my calibration
That is because you have the activation set to 0 milibar (-14.7 psi or 30 inches of vacuum). Set this to something reasonable like 3 Psi.
Nineteendc5
Spunkster wrote:That is because you have the activation set to 0 milibar (-14.7 psi or 30 inches of vacuum). Set this to something reasonable like 3 Psi.
I set it like that to see if the boost controller would continously click and it wouldnt.
You are complaining that it is always open. The reason it is always open is because you have it set that way. If you do not want it to always be open then change you setting as I have suggested.
Nineteendc5
It was set at 2 psi before is what i'm saying. I just didn't change it before i posted it.
Nineteendc5
Completely uninstalled kmanager and reinstalled and it seems to be working now
sohc_mshue
Post by sohc_mshue »
I have the same issue with 3.3.1. Ive never had this issue on cars with the older versions. I even tried reinstalling it.
