Datalog Corrupt
linex3
Datalog Corrupt
Post by linex3 »
When I datalog everything is fine. I am datalogging with my laptop as well. I continue to save the run, although whenever I try to reopen the file
I get a message saying the calibration is corrupt. This happens every single time I save a datalog. Not sure what to do.
-Linex3
Re: Datalog Corrupt
Please follow the guidelines http://www.hondata.com/forum/viewtopic.php?f=29&t=10108
If you have a file which will not open, email it to support@hondata.com
linex3
Re: Datalog Corrupt
Post by linex3 »
- serial number of your FlashPro --FP-SI-US-16180
- the calibration (as an attachment)
- a datalog of a problem (as an attachment)
- what sort of vehicle you have--2011 FA5
- what sort of ECU you are using -stock
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc)-NO
- a specific description of the problem
Calibrations load fine. I can datalog and look at it after. Although, if I save and try to reopen the datalog it says it is corrupt.
Re: Datalog Corrupt
The datalog opens just fine here. You may have setup a gauge in your diaplay that is causing the error, try using a different display template.
linex3
Re: Datalog Corrupt
Post by linex3 »
Ok sweet that fixed it. I was using a different template. Now it shows everything and thanks for the help.
