ECU Installation and ground...
mazzas
Post by mazzas »
It's unclear to me if the ECU chassis should be grounded or not. If mounted in the original location inside the stock ECU chassis then the mounting screw would (I think) provide a ground. But if I mount inside the glove box (as suggested) then do I have to ground the ECU chassis? Or is it not necessary?
Re: ECU Installation and ground...
It is not necessary to ground the ECU case.
mazzas
Post by mazzas »
Thanks!
