FlashProManager V1.8.3 beta (Bluetooth)
V1.7.3 (2 Apr 2014)
  • FlashPro firmware updated to version 61
  • Bluetooth enabled
  • [07-08 TSX] Added ability to program AT ECU with MT program
  • [TL] Added ability to program AT ECU with MT program, only base model ECU (RDA-A85)
  • [2006 R18 MT Civic] Added support for the RNA-A150 calibration.
  • [CR-Z] Fixed misfire code disable.
V1.8.0 (3 Apr 2014)
  • FlashPro firmware updated to version 62
  • Fixed Bluetooth detection
V1.8.1 (4 Apr 2014)
  • FlashPro firmware updated to version 63
  • Fixed programming with button for non Bluetooth FlashPros
V1.8.2 (14 Apr 2014)
  • FlashPro firmware updated to version 64
  • Fixed non Bluetooth FlashPro sleep
V1.8.3 (29 Apr 2014)
  • FlashPro firmware updated to version 65
  • [2006 Civic Si] Added P0128 disable.
  • [2012+ Civic] Added IAT compensation.
  • [2012+ Civic] Added support for RX0-X02 through RX0-X04, Mexico.
  • [2007 TSX] Added misfire disable.
DomGSR-T
Re: FlashProManager V1.7.3 beta (Bluetooth)
Post by DomGSR-T »
I guess, us the TL guys will have to wait again for the full throttle plate closure features...
•[2006 Civic Si] Added parameter to enable full closure of throttle plate on deceleration & throttle opening vs flow table.
•[2012+ Civic Si, ILX] Added minimum throttle opening compensation table to allow for full closure of throttle plate on deceleration.
Gernby
Re: FlashProManager V1.8.0 beta (Bluetooth)
Post by Gernby »
Did live tuning get fixed for VTEC window pressure table on '12+ Civic Si?
'06 NFR S2000
Gernby
Post by Gernby »
Also, do you know if FlashPro Bluetooth will work with Harry's laptimer?
Do you have any documentation you can provide about what is available via Bluetooth for people that want to develop their own software?
'06 NFR S2000
VitViper
Post by VitViper »
Did we get a ninja patch to include that '14 ILX ECU?
VitViper
Post by VitViper »
Also the installer seems to be saying it's 1.7.1....
Yes.
What is Harry's laptimer? If it uses ELM327, then it should work, but elm327 applications are notoriously buggy and I would not know until I tried it here.
See the bottom of the mobile page http://www.hondata.com/mobile.html We are considering making Hondata Mobile open source.
Not as far as I know. Has Honda sold any 14 ILXs yet? Do you know the calibration ID?
The application is ok (1.8.0.0). I'll recompile the installer again.
VitViper
Post by VitViper »
Hondata wrote: Not as far as I know. Has Honda sold any 14 ILXs yet? Do you know the calibration ID?
Yes... I had one come into the shop last month, had a discussion with Doug about it... the ECU is "R9B-A03", which is listed as supported in the 1.6.3 update:
[ILX] Added support for the R9B-A03 ECU
However that's not the case -- FlashPro refuses to recognize the ecu and will not lock/flash the car. We were told this would get fixed in the "next beta". :/
We even had him send support info like 4 weeks ago, per Doug's request.
Hondata wrote: The application is ok (1.8.0.0). I'll recompile the installer again.
Yeah I noticed the app was OK.
R-12914
Post by R-12914 »
Today, i have Upgrated/Updated my Flashpro Manager to Softwareversion 1.8.0.0 and the Flashpro Firmwareversion to 62, but if i will upload a Calibration from my Flashpro to my ECU in the old way, the Flashpro it does not work.
I have Uploadet the Cals from my Notebook to the Flashpro over the Flashpro Manager without any Problems, but the single problem is to upload the Cals to my ECU via Flashpro.
Can i describe the ECU infinitely often, or is it limited?
Please help me... :(
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
what error are you getting?
R-12914
Post by R-12914 »
Spunkster wrote:what error are you getting?
If i try this:
1. Plug the FlashPro into the diagnostic connector and switch on the vehicle ignition.
· Primary calibration - press the Program button for at least one second.
· Secondary calibration - holding the Datalog button down, press the Program button for at least one second, releasing the Program button before the Datalog button."
Than the FlashPro does nothing!
I have also upload the Cals again from the Notebook to the Flashpro and than from the Flashpro to the ECU, but the same as before! :(
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
we are looking into this now.
R-12914
Post by R-12914 »
Spunkster wrote:we are looking into this now.
Very thanks! :)
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
VitViper
Post by VitViper »
FYI, I emailed Derek -- but the Civic calibrations are still unusable on highly modified cars that exhibit *any* misfires at all (think large injectors -- my car has 2200's). Lights up the dash like a christmas tree and car goes very slow.
VitViper wrote:Yes... I had one come into the shop last month, had a discussion with Doug about it... the ECU is "R9B-A03", which is listed as supported in the 1.6.3 update:
Yes, we added the binary R9B-A03 in 1.6.3 but the problem you had was related to the ECU part number. It should work now.
So you want misfire disable on the 06 Civic? We'll add it in.
