Data Logging problem
aria
Post by aria »
-S300 V2 serial number 20894
-ECU P28
-Honda Civic 3 doors 1992 D16Z6 NA
-Std air filter, Skunk2 intake manifold, Skunk2 TB ,Hondata intake man gasket,Standard Injectors (240cc), AEM Uego wideband O2
Software SManager 2.2.7
When i was doing data logging, after the table switched to 2nd table (high speed fuel table) or when i reached VTEC point, there's no afr's data on table cells , only highlight on cell. But in first table (low speed fuel table) it could log the afr's data. Re-boot the laptop didnt work as well. I've downloaded the new updated software 2.3.0 but the problem still there.
Regards
Re: Data Logging problem
Under Options, settings, sensor overlay, what settings to you have. It appeasrs to be working normally with the datalog and calibration you have sent.
aria
Post by aria »
when switch to high speed fuel table it goes blank, no afr can be recorded, can you see it at my datalog that i posted.
thanks for reply spunkster
Change your max throttle to 120%
aria
Post by aria »
Solved, thank you so much Spunkster.
