2007 s2000 flash pro. Help !!!
Hieus2k
Post by Hieus2k »
After driving for couple years now the flash pro is stop working. When it plug in it doesn't have power, the power light should be on either with or without the key in ignition. Check the wiring and see nothing wrong with it. Took the flash pro out and try to drive without it plug in and the car it's lean, plug it back on and it drive fine for 2 days then can't crank it up, have to change the spark plugs and it's good for 2 days and it won't crank it up. The tuner said he can't do anything without the wiring schematics. Help please
Re: 2007 s2000 flash pro. Help !!!
The FlashPro does not need to be plugged in for the car to run. Check & clean the master ground on the back of the cylinder head.
Hieus2k
Post by Hieus2k »
In already check that and it good, check with the tuner and he said nothing he can't do without the wiring schematics, it's not reflashed, should I send it to you guys and have it check out? Or what should i do ???, also I checked all the wiring and fuses are all good
You could call for a RMA so we can check the FlashPro, but you need to fix the underlying problem, which probably is the ECU grounding through the FlashPro.
Try the FlashPro on a known working car. If it works normally then you know you have a wiring fault in your own car.
Hieus2k
Post by Hieus2k »
Will try! Thanks
Hieus2k
Post by Hieus2k »
I checked with other car and it doesn't works. Plug it in with my friend flash pro and it have power. Should I send it to you guy to check it out ?. And tell me what I need to do ?
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions (include a link to this thread):
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Hieus2k
Post by Hieus2k »
Sorry for being slow but when I go to hondata.com and looked under support there is no place to send a email. It is easier if I send a email directly to you?
