Hondata s200 led flashing slowly but no cel on
Type_r_eg
Post by Type_r_eg »
Hey guys I have a s200 with a slowly blinking led but I have no cel on. The cel will come on a few seconds but goes off as it should. I've checked for bad connections but found none. This is a brand new s200 I've bought from someone still in the original box and plastic.
My ecu is a usdm p72 which has already been socketed and chipped running fine before I got the s200. So I got the s200 and hooked up to 4pin cn2, j12 cut, j1 jumped.
The chipped I got it from I had it tuned from phearable.net, could the chip b the problem? It's not a blank chip cause I've been driving on it for a year.
Any help apreciated
Type_r_eg
Re: Hondata s200 led flashing slowly but no cel on
Post by Type_r_eg »
Yeap
You need to make sure that the chip you are using was burned with a Hondata program or it will not work with the s200.
Type_r_eg
Post by Type_r_eg »
Can I do that myself with a chip programmer or how do I go about that?
Thanks for the reply
