s300 CEL stays on. both green and red LED's stay on
ef8904
Post by ef8904 »
I was replacing the motor in my crx (B20 BLOCK TO LS BLOCK) and thought i was ready to start the car but evidently forgot the ground to chassis since i have the battery relocated in the back. the battery was grounded by the tail lights. and the harness was grounded to the thermostat housing. so who do i send it to or what do i look for burned up?
ef8904
Re: s300 CEL stays on. both green and red LED's stay on
Post by ef8904 »
the car was running fine last week. and i only realized i had a problem when i clicked to acc and smanager was telling me i only had 10 volts
Use a multimeter and check the voltage from the battery to the ECU and find where the voltage is droping. Relocating the battery typically causes more problems than it solves.
ef8904
Post by ef8904 »
I dont believe there is still a voltage issue because i plugged my s300(p72) into a 94 civic 5spd and i still cant get any signal to smanager. turn key to acc and fuel pump primes, CEL stays illuminated. and i still cannot datalog.
What happens when you try to upload to the s300?
ef8904
Post by ef8904 »
Would not let me upload. I pulled my module off and i see where it has a short =/ how much to fix or upgrade to version 3 if its an option still?
Post a picture of what you see.
ef8904
Post by ef8904 »
Heres a pic
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions (include a link to this thread):
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
ef8904
Post by ef8904 »
oops read that to fast. i gotcha. thanks!
ef8904
Post by ef8904 »
"how much to fix or upgrade to version 3 if its an option still?" .. you never contaced me with any options. you simply charged me $250 to replace the board back with a version 1??
replied via email
