Just tried the hondata mobile
DomGSR-T
Post by DomGSR-T »
Hi,
Not sure if there's a setup to do before using the app but, my TL cannot do between 100-170mpg at 70mph :) so there's something wrong there, also, can I change the Fahrenheit temp reading to Celcius? mpg to L/100km? mph to kmh? Also, is it normal that I have to enter the bluetooth password everytime I want to use it? Maybe there's a documentation somewhere on how to setup and use/customize the app that I don't know of?
Re: Just tried the hondata mobile
What OS are you using (android or IOS)? There are settings for the injector size & dead times, and the temperature unit. The bluetooth password probably is because of the bluetooth stack on the phone - some only work with a PIN of 1234 or 0000.
DomGSR-T
Post by DomGSR-T »
I'm using Android, where/how do I change injectors size? and what value should I use to get good mpg readings?
Under 'Settings' there is injector size and injector dead time.
DomGSR-T
Post by DomGSR-T »
Ok thanks,
What is the injector size and injector dead time I have to use for the TL? Also I can change everything to metric except the MPG, can this fonction be added please?
Copy the settings from your calibration. Use the injector dead time at 14V.
DomGSR-T
Post by DomGSR-T »
Ok thanks I'll try this! What about the L/100km vs MPG reading? will this be added ?
DomGSR-T
Post by DomGSR-T »
I put 732 like my 14v dead time settings.. I'm at 70 mpg on the highway on the highway now... Maybe I need the put the 355 fuel consumption value?
DomGSR-T
Post by DomGSR-T »
A Value of 355 give me 48-50 mpg at 75mph... still not good... do the civic guys have that problem? maybe the calculation is not correct for a 6 cylinders?
Also why does the ECT2 is not available in the custom display?
DomGSR-T
Post by DomGSR-T »
Any update for us V6 guys?
6spd-GERCO
Post by 6spd-GERCO »
Bump to this topic, I have had the same issues with the Hondata App for my iPhone. I've mess around with the dead time to get it in range but i don't know if this is the best way of going about it. Any input?
DomGSR-T
Post by DomGSR-T »
V6 support is not a priority as I can see...
Please, no trolling. You will need to change the injector size / dead time to get the correct values.
DomGSR-T
Post by DomGSR-T »
would this update fix our mpg reading problem?
•[TL] Fixed Bluetooth datalogging of the MAP sensor
There's no bug on our end to fix. Given the injector dead time and injector size are user adjustable, you can change the slope and intercept of the injector duration to fuel consumption relationship to anything you want, so it is up to you to determine what the settings need to be.
