AFR issue D10 ELD
forryk
AFR issue D10 ELD
Post by forryk »
Hey guys!
Have a AFR issue with my s300. I have the AEM uego connected to D10 and resistor cut in the ECU. Still the s300 wont read lower then 12.1 but the gauge shows 10-11. Any ideas how to fix this?
Re: AFR issue D10 ELD
HAve you checked the voltage on the output from the AEM using a multimeter?
retroid
Post by retroid »
you removed both resistors, or just one?
where do you connected the wideband +V and ground?
how long are the wires?
(lower than 12.1 is arround 1.20V)
