Help hondata s300 problem
taveyeg6
Post by taveyeg6 »
The s300 has no led light next to the USB port only when I up load it then it blink red but still don't work. I Change the ecu still same problem so I borrow a friend s300 up load my calibration work fine.so I put my s300 in his ecu same problem. But all this happin after I had got it tuned so I'm not sure if the s300 is bad or it's just locked out please help
Re: Help hondata s300 problem
What is the serial number that is on the s300 board inside the ECU? From Help, About, what version of software are you using?
taveyeg6
Post by taveyeg6 »
23672 i had it for less then a year what do u think i should do
taveyeg6
Post by taveyeg6 »
i update it to the latest version i think its 2.3 any thing u can do to help would b great
Go to Help, and click on about, it will tell you the exact version of software you are using. What does that say?
When you upload to it does it give you an error message?
taveyeg6
Post by taveyeg6 »
yea its version 2.3.0.0
taveyeg6
Post by taveyeg6 »
no there's no error massage when upload
Are you able to datalog and does it run the car correctly? Are you just worried becauuse the lights do not do what you expect?
taveyeg6
Post by taveyeg6 »
no it dont datalog no more it dont even start the car i have to use my friend s300 module in my ecu to move my car back home.
Send and email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions (include a link to this thread):
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
taveyeg6
Post by taveyeg6 »
it has been sent
