distributor max to get 16 degree after change new coil
excaliburcombo
Post by excaliburcombo »
hello need some advice as my coil died so replace with new ign coil. After complete replace i want to set back base ignition to 16 degree using timing light.. The distributor go max to get 16 degree. My question is this coil causing the issue.
Here the step
1.Replace bad coil
2. start up engine and make it to normal temp ( after fan on)
3. Set base ignition in SManager to 16 degree
4. Put timing light in 1 spart wire and shoot for crank pulley
5. Recheck back crank and cam timing no off tooth.
Re: distributor max to get 16 degree after change new coil
What mark on the pulley are you using?
excaliburcombo
the cam mark piston 1 at TDC. cam pulley UP arrow at the top.
You can't use a mark on the cam pully to measure the ignition timing. You must use the single white mark on the crank pulley and a timing light.
excaliburcombo
yes i try to set base timing using timing light. the single wire run to spark wire piston 1. Also using my friend timing light result still same. Thanks.
Is this a dial back timing light or a fixed timing light?
excaliburcombo
using 2 fixed dial timing light. Thanks.
What mark are you looking at on the crank pulley?
excaliburcombo
red mark. the middle mark of three mark on crank pulley.
Has the head been milled? Have the cams been degreed? Are you using adjustable cam gears? What block is this? What head?
excaliburcombo
The head not been milled. Im using standard B16a cam, cam pulley and engine block. The head stamp PR-4. Thanks for your help.
You cannot use B16A cams in a PR4 non-vtec head.
excaliburcombo
Sorry Spunkster. Typo error. It stamp with PR3-4. Thanks...
You said a fixexd dial timing light. Is ist a fixed timing light that cannot be adjsuted, or is it the kind with a dial to set to the desired timing?
excaliburcombo
Im using fix timing light that cannot be adjust. Thanks.
