K-pro and Multiplex output
BrianZ
Post by BrianZ »
I'm currently setting up a new car with a AIM dataloger system. The last car had a PRB ecu and I had no problems. The new car has a PNF ecu in it and I cant seem to get them to work together. Will this ecu support the Multiplexer output?
Re: K-pro and Multiplex output
You need to use a PRB calibration, but you can use that calibration in a PNF ECU.
See http://www.hondata.com/help/kmanager/serialoutput.htm
BrianZ
Post by BrianZ »
how can I verify whats in the ecu is a PRB calibration ?
It tells you in the KPro window under Software then ECU Type.
Only a PRB calibration will have the multiplexor option.
BrianZ
Post by BrianZ »
Thank you for your help!
