Update SI 2014
SI12
Update SI 2014
Post by SI12 »
Hi,
I would like to know if my flashpro that i have on my 2012 civic SI will be compatible with the 2014 civic SI. I suppose i will have to wait for a update and if so, i would like to know if you have any plan to release an update soon.
Thank's.
Re: Update SI 2014
What is the ECU part#?
SI12
Re: Update SI 2014
Post by SI12 »
Spunkster wrote:What is the ECU part#?
I will have the car next week, so i will be able to send the ECU part# only at this time. Sorry.
SI12
Re: Update SI 2014
Post by SI12 »
The # is 37820-RX0-A21
Re: Update SI 2014
This is not yet supported, but we are looking into it.
SI12
Re: Update SI 2014
Post by SI12 »
Spunkster wrote:This is not yet supported, but we are looking into it.
Ok, thank's.
Pir8pete
Re: Update SI 2014
Post by Pir8pete »
@ Hondata, any news yet? I was about to start a thread asking, and seen this one. I too have an 2014 Si. Have to guys compared the stock ECU programs 2012 and 2013 to 2014 to see if there's any difference? I ask because I know there's a horse power and torque increase and there maybe sight changes Honda has done to the programing to accommodate the hardware changes.
Re: Update SI 2014
It's a couple of months away.
Pir8pete
Re: Update SI 2014
Post by Pir8pete »
Hondata wrote:It's a couple of months away.
How do you guys keep on top of each "new" build. Does Hondata go out and buy the car for R&D or do you pick willing ppl that bought the car?
Also here's my Canadian 2014 Si ECU # 37820-RX0-A21 which is the same.
KDiggityDog76
Re: Update SI 2014
Post by KDiggityDog76 »
It may be helpful to merge this discussion with the similar one under the "Applications" thread:
http://www.hondata.com/forum/viewtopic.php?f=10&t=17328
jstingley
Re: Update SI 2014
Post by jstingley »
Im also having an issue u say I can use 2012 cals on my 2014 si right but I keep gettin an error saying u cannot use a calibration ment for a 2012 flashpro on a 2014 flashpro wats the issue here it wont let me load my supercharger basemap ive got both a 2012 map and a 2013 and both give me the same error message because im assuming they werent created using a 2014 flashpro or at least when they selected the vehicle they dint select 2014
Re: Update SI 2014
Post the calibration you are having difficulty with
jstingley
Re: Update SI 2014
Post by jstingley »
here is the calibration that wont load onto my flash pro...all the preloaded ones will
Re: Update SI 2014
Make sure you have everything plugged in and the key in the on position when you do this. We have tested this calibration and it works as it is supposed to with a 2014.
From Help, About, what version of software are you using?
jstingley
Re: Update SI 2014k
Post by jstingley »
The new 1.9 watever I updated it when I got it here is wat I get when trying to load it
