distributor
freezingmoon
distributor
Post by freezingmoon »
so with the cpr kit installed does the ignitor in the distributor still effect the ignition???
Re: distributor
No it does not.
freezingmoon
Re: distributor
thanks, im having a really weird ignition issue that im trying to diagnose...its something that ive never experienced before and very difficult to describe other than a very random and sudden loss of power at any weher in the rpm range, almost feeling like a brief stall... no codes are thrown... been chasing my tail with it for a couple months now...
freezingmoon
Re: distributor
any help would be GREATLY appreciated!!!
everything on this set up is brand new... no corners cut at all on the build, just cant figure out this weird glitch that i can only assume is ignition related...
thanks!
Re: distributor
Without the calibration and a datalog showing the problem it is impossible to speculate on what the issue is.
freezingmoon
Re: distributor
so if a make a datalog can i post it here and maybe u can help? how long of a log should i record? difficult thing is that the occurence is so random its not easy to know when it will happen, its very frustrating to say the least... thanks again for at least corresponding, much appreciated!
Re: distributor
YOu must record the problem. You can always trim the datalog and just upload the section where the problem occurs.
freezingmoon
Re: distributor
ok thanks, i will record and post on here in a day or two... thanks so much!
