FLASHPRO Not Detecting VIN Nor ECU
Dondada03
Post by Dondada03 »
I have on 03 UKDM CL9, i have installed a used 07-08 tsx AT ECU, i have also installed my CAN adapter. However, after installing these i decided to test my flashpro to see if the ECU would be detected. The flashpro recognized everything except the ECU. Is this because i have not inserted my VIN into the ECU nor have i had my immobilizer paired with the ECU? or should the flashpro recognize the ECU regardless of this? Please provide me with some feedback as i wish to have this issue rectified.
Re: FLASHPRO Not Detecting VIN Nor ECU
It is the CAN wiring. Double check everything.
Dondada03
Post by Dondada03 »
i re pinned the wires, and the ecu was still undetected, however the binary for the ECU was detected where a green tick was displayed. every other subsection under the ecu tab had the I icon. can you provide some further feedback
What binary was the FlashPro detecting? It might be easier if you send the support information from the help menu.
Dondada03
Post by Dondada03 »
it detected US 07-08 TSX AT ECU
Which one? Send the support information please.
Dondada03
Post by Dondada03 »
ive attached the screen shot
Dondada03
Post by Dondada03 »
data from flashpro
Hondata wrote:Send the support information please.
Dondada03
Post by Dondada03 »
support information such as? i am not certain of what information ur askng
From the help menu, with the FlashPro plugged into the vehicle and the ignition on, select 'Send Support Information to Hondata'.
Dondada03
Post by Dondada03 »
i sent the support information about an hour ago
It is not detecting the ECU. This is either the ECU itself or the CAN wiring.
Dondada03
Post by Dondada03 »
Problem solves ECU is now Detected. One the Wires was not all the way in in the DLC connector.
Good.
