s300j problems plz help
tlarson865
Post by tlarson865 »
im new to s300 ive tuned on aem ems and i just picked up the ecu locally had been working fine until...
ok so this morning i drove the car to work , modded obd2b gsr running s300j with zerg jumper harness, drove great did some pulls and tune was on point may be a little rich. after work i hopped in and it was a bit hard to get it to start and stay idling, i figured may be the engine is cold and ill have to make some adjustments to my parameters. after it had warmed up a bit it idled fine, went to do a pull and it pinned lean and obviously misfired and didnt go anywhere, i noticed it was throwing a code 9 cyl sensor. also throwing code 13 BARO sensor but had this before the problem, no matter how much i richin the map nothing changes
i now got the car to idle, when driving on highway its fine around 10% throttle much more than that it starts to lean out, ive checked fuel pressure, injectors, fixed cyl sensor code 9 got new coil cap and rotor, recently swapped my s300j out for my p72a05 and it ran fine beside being extremely rich im running s2000 380cc stock injectors
is there a setting somewhere in smanager im fucking up
thanks in advance guys!
Re: s300j problems plz help
