S300 / SManager
hintingtse
S300 / SManager
Post by hintingtse »
Hi there,
I have a Honda CRX (EF8) and was previously using S300/SManager Version 2. I have recently brought a similar computer, but Version 3 from a local authorized dealer. When I put my car on dyno, I found the following problems:
(a) I initially set the rev limit to 8,000rpm, and the rev did cut at 8,000rpm;
(b) Then I set the rev limit to 8,300rpm, but the rev still cut at 8,000rpm;
(c) Then I set the rev limit even higher at 8,600rpm, but the rev still cut at 8,000rpm.
Any words of wisdom on the above issue? FYI I am running on OBD1 and have updated all softwares.
Thanks in advance from Hong Kong.
AREA876
Re: S300 / SManager
Post by AREA876 »
Post calibration and a datalog
Re: S300 / SManager
Are you uploading? Do you have real time update set on?
