08 civic VSA brake and ABS lights on
Aflo026
Post by Aflo026 »
I'm having some issues, all of my abs vsa and brake lights are on shortly right after the TCS was installed. Also I am getting a CEL of ELD low circuit voltage P1297. I'm kind of lost at the moment for ideas
Re: 08 civic VSA brake and ABS lights on
Before you do anything else check the wiring connections and that the switch in the Traction Control was set to 'Active'.
Aflo026
Post by Aflo026 »
Thanks for the help! I Actually did not select the active switch to on. Thank you again. BTW i love the help you guys offer along with the great products
Glad it is working.
