Problem with fuel trim value.
BAGEN
Post by BAGEN »
When I look at my tune I flash pro I can't se any value numbers in the fuel trim window.
The 3d graph is showing correctly but not in the tables.
Why is that?
Is it an settings thing that I have missed?
I can se the value. Numbers In the tables when I do a pull but not when I'm offline.
Re: Problem with fuel trim value.
'Fuel trim' = 'Fuel overlay?' Normally it is because the display settings are too restrictive. Go to options, settings, lambda overlay, settings and make sure the throttle, gear, cam angle & MAP are not stopping the sample points from being shown.
You have to have a datalog loaded to see these values. They are not part of the calibration.
BAGEN
Post by BAGEN »
Thanks for the answers...
