05-06 RSX KPro Vs. S2000 Kpro
KSeries4Life
Post by KSeries4Life »
Are the only difference between these ECU packages, the S2000 adapter and brackets?
Just wondering because I will be doing a K-Swap into a 2004 S2000 and I want to make sure I can get the gauges working and I won't need the S2000 adapter. Hoping I can just order the 05-06 RSX KPro because it would be setup to read a high-frequency transmission sensor.
Thanks!
Re: 05-06 RSX KPro Vs. S2000 Kpro
No, the 05-06 RSX K-Pro will not work for this. We don't really make a system that is designed to work with this, so you are kind of on your own with working out the bugs and glitches. The K-Pro setup for the S2000 would be best, but it is not setup to work with VTC the way it is designed.
