fuel level gauge
neoarks
fuel level gauge
Post by neoarks »
Hello guys !
I'm using on flashpro the last version , and i have problems whit the fuel level gauge on map calibration.
The gauge falls dawn on 20km after fuel warning
Falls down rapidlly from 1/2 tank
Can i do to correct that????
Re: fuel level gauge
Give it some time to adjust and it should work correctly. We do not alter the way it functions in any way.
neoarks
Post by neoarks »
Thanks for helping me.
The car have more than 3000 km / 1800 m from the final calibration and no improves.
What calibration are you using? Can you post it here?
neoarks
Post by neoarks »
If you refeer tol MAP based calibration?
What injectors are you using?
neoarks
Post by neoarks »
RC750cc fuel injectors & rotrex supercharguer.
Your injector size is set to 1200 cc under 'Injector flow for fuel economy calc'. I think this is the cause.
neoarks
Post by neoarks »
Hondata wrote:Your injector size is set to 1200 cc under 'Injector flow for fuel economy calc'. I think this is the cause.
Thanks!
I have tried many values from 0,750,1000, 1200..... Up to 1600 and i got the same results (the gauge is not working properly). My quesiton is, which value would you think is convenient for my injectors "RC750"?
It should be what the injectors flow at the same test pressure as the stock injectors, so 750cc. If you change this value it might not take effect until you fill the fuel tank again.
neoarks
Post by neoarks »
Thanks again.
I'm going to try it now
neoarks
Post by neoarks »
Hi!
After several tanks i cant see improvements.
Could someone let me know which other components affects or has influence on the fuel level gauge?
neoarks
Post by neoarks »
Any ideas?
Put in the stock injectors. Disable boost. Upload the 'stock equivalent' reflash using AFM. Retest over one or more tanks.
nunoctr
Post by nunoctr »
neoarks wrote:Hello guys !
You can't correct this on map cals.
You need to use a afm cal (or afm cal with map fuel tables). With this cals you don't have problems.
