Question about Traction Control!
R-12914
Post by R-12914 »
Hi,
do i need to fit/plug in this item always to the traction control module to adjust the traction control?:
http://www.cplracing.co.uk/site_images/ ... /185-2.jpg
Or it is not necessary or work without this part?
So once set and then unplugged?
Thanks!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: Question about Traction Control!
It needs to be connected at all times.
R-12914
Post by R-12914 »
Please can you tell me also the dimensions of the parts where including in the Hondata Traction Control?
I mean the exact dimensions of the "Traction Control Module" and the "Switch Module" in width, height, depth and screw mounting.
How much is in each case the cable length?
I need this dimensions, that i can check, whether the parts i can put into my car.
Thanks & Greeting,
Matthias
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
http://www.hondata.com/help/tractioncon ... ations.htm
The switch to main box cable is 7 feet long
R-12914
Post by R-12914 »
The dimensions where you have posted are for the "Traction Control Module", how much are the dimensions for the "Switch Module"?
Which length is the cable from plug to the cable pins to the abs-sensors?
I need to know the exact dimensions!
THX!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
The switch box is 1.5" high x 2.0" wide x 1" high, with a flange on the long side with total width of 2.865".
You can also take the switch circuit board out of the switch box, drill holes, and mount it elsewhere.
Mintegra
Post by Mintegra »
I only have one question about hondata traction control, does the little black box know magic? I have a boosted, stroked, sleeved integra (it's as ridiculous as it sounds) and when I lay down 360 ftlbs of torque in 4th and 5th the car just moves. This and an LSD are a must on any honda. It works so well it fools your senses and logic. Well done everyone at hondata your products are amazing.
R-12914
Post by R-12914 »
Hondata wrote:It needs to be connected at all times.
Is it right, that if i do not use the "Use PID Control" hook...:
...Then i do not use the PID like this?:
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
Hondata, please can you answer my question?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
What is your question?
R-12914
Post by R-12914 »
Hondata wrote:What is your question?
This post:
http://www.hondata.com/forum/viewtopic. ... 387#p85180
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
I do not understand your question.
R-12914
Post by R-12914 »
With PID/PID control, do you mean this one?:
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
The picture is of the control box, which switches traction control on and off as well as selecting target slip. I'm not sure what the link to PID control is.
R-12914
Post by R-12914 »
Hondata, you do not understand me!
You have written, that the control box (the dial with potentiometer) is necessary to run the Hondata Traction Control!?
Here is the control box:
What i mean is as follows:
Do i need this control box always, or only if i use the "Use PID Control" hook see as follows:
Or is the PID and the control box not the same?
Do you understand me, now?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
