Changing MAP parameter
chrisregan
Post by chrisregan »
Hello, I am new with using Smanager, This is a very noob question but I just changed out my stock map sensor for a Hondata 4bar, when i go into parameters it wont allow me to select which MAP sensor type, it is just grey and wont let me click on which MAP I want to select. The laptop is connected to my s300 and the ignition key is on and datalogging is online. Can somone steer me in what im doing wrong? thanks
crucian
Re: Changing MAP parameter
Post by crucian »
Did you select the "Replacement MAP Sensor" bubble?
You must open your calibration to be able to edit it. Then after you make the changes you must upload it to the ECU.
