02-04 k-pro ´06 tranny
EGK2082
Post by EGK2082 »
I have 02-04 KPro and '06 if tranny, and perfect connect k-tuned vss converter.
How do I set the speed sensor in KPro?
-Normal speed sensor
-Countershaft speed sensor-driven (2005-2006 rsx)
-No speed sensor signal-provide constant speed
I have setting -Countershaft speed sensor-driven (2005-2006 rsx), I Can Have damaged something??
Re: 02-04 k-pro ´06 tranny
More than likely you should have it set to normal. Have you contacted K-Tuned about this?
We only support the 02-04 transmission. You need to contact KTuned.
EGK2082
Post by EGK2082 »
yes, there is that setting in Normal
but wanted to know if this could cause any damage to the ecu?
