ERROR:Daughter board communication When cranking voltage low
EGK2082
Post by EGK2082 »
eg/k20z3, I have the following error: Daughter board communication When cranking voltage low, ground perfect, new battery oem location. charging 14v, drops to 12v and misfire in the blink of an eye, and becomes perfect to 14v
Re: ERROR:Daughter board communication When cranking voltage
Is the battery in the OEM location for an EG, or OEM for a K20?
EGK2082
Post by EGK2082 »
Spunkster wrote:Is the battery in the OEM location for an EG, or OEM for a K20?
EGK2082 wrote:drops to 12v and misfire in the blink of an eye, and becomes perfect to 14v
With the engine running, or when cranking?
What does the voltage drop to when cranking? Can you make a datalog?
Have you measured the voltage with a multimeter at the ECU when you are cranking and get this error?
EGK2082
Post by EGK2082 »
happens with the engine running
I'll make a datalog
Best to use a multimeter on the ECU pins (A2 & A4) when cranking. Be very careful not to short anything out.
The Spectacle
Post by The Spectacle »
I've had this same error/problem recently. The ECU would throw the code immediately after the motor started. I had a friend check over everything and I had a bad ground at the battery. We fixed the ground and the problem hasn't returned. I would start there and get a second opinion on it from someone good with wiring to make sure that's not the problem.
EGK2082
Post by EGK2082 »
Problem solved, one of the ground wire, had not had good ground, had painting.
Glad it is fixed and thanks for posting the solution.
EGK2082
Post by EGK2082 »
Hondata wrote:Glad it is fixed and thanks for posting the solution.
Thank you for helping me.
perspective
Post by perspective »
I had the same issue, I replaced the ground on the battery never had any problems after that.
Also , if you turn the key to on , wait for the fuel pump to prime and the kpro clicks, then turn the engine,
this trick helps to get less check engine lights while you figure what is caussing it
