CHANGE ECU AND DISABLE IMMOBILIZER
demorou
Post by demorou »
I bought a new ECU for k20a2 if I remove the immobilizer what happens?
the engine starts?
my car can be stolen easily?
Re: CHANGE ECU AND DISABLE IMMOBILIZER
Do you have a K-Pro?
demorou
Post by demorou »
yes i have kpro
If you disable the immobilizer it makes it very easy to steal. It will start just by turning the ignition switch on.
demorou
Post by demorou »
my ecu is e11 if i change this whit ecu e12 how many problems encountered?
i possesed kpro for e11 whit ecu e12 is compatible?
and i have problem whit immobiliser?
Why are you changing the ECU?
demorou
Post by demorou »
my ecu is burned
You should contact CPL Racing in the UK about this transfer as they will be able to assist you.
