c8 capacitor damaged
wil60
Post by wil60 »
Hello, I use a s300 for almost 1 year without problem. but yesterday being the relenti the ecm s is extinguished. after having opened the ecu c8 condensaeur is toast. what it may come?
Re: c8 capacitor damaged
What version & serial number is your s300? Can you post a photo of the damage?
wil60
Post by wil60 »
it is a v2. I will take the photo and serial number today
wil60
Post by wil60 »
my serial number is 24117. following photo.
when I unplugged the s300 engine is operating normally.
Where are you located and where did you buy the s300?
Does the s300 get hot?
wil60
Post by wil60 »
currently it is nothing, not even warm. I am from France, I purchased my s300 ais in xenocron
wil60
Post by wil60 »
no answer? too bad for me
Xenocron sold to you directly?
Email support@hondata.com for a RMA.
wil60
Post by wil60 »
07/10/2013 yes directly. I'd like to know anyway what could caa caused destruction. I would not want to destroy a second
I have not seen this before on a S300. On other ECUs usually a floating ground plane which causes reverse polarity for the components are the cause of damage.
wil60
Post by wil60 »
what is surprising is that after c control all seems ok, the ecu works without Hondata. might this come from analog input?
Normally once the ground floats then it grounds through the USB cable. I'm not sure if this is what has happened in your case.
wil60
Post by wil60 »
thank you I will look at that
