S300 wideband little question
ferlandez
Post by ferlandez »
Hi, i got a hondata s300 rev 2. i got it installed on a p28. I want to tune my A/F on my B16A.
I'm from kpro world i already tune A/F etc etc on some RSX. but now my question is:
i have a rsx 02-04 ntk primary O2 sensor part 24665. i would like to know if i can use them to tune my B16A and completly remove the stock narrowband sensor from my civic and use the closed loop option on the S300.
Thanks a lot for your help and sorry about my bad english.
Re: S300 wideband little question
The OBDI ECU does not have a wideband controller. The RSX ECU (except PRA) does. The OBDI ECU cannot control a wideband o2 sensor - you need an external controller, like the PLX. http://www.plxdevices.com/product_info. ... EMOSMAFRV2
ferlandez
Post by ferlandez »
So with that controller i will can completely remove the stock narrowband sensor ?
Yes, you can run in closed loop using the PLX voltage output.
