Base map for S2000 with Rotrex kit, Flash pro and ID1000 inj
antkouv
Post by antkouv »
Hi all,
Does anyone have a FlashPro map setup for ID1000 injectors? I only need it for my car to have an ok idling operation and will fully tune it after that.
Thank you.
Antony
Re: Base map for S2000 with Rotrex kit, Flash pro and ID1000
You need to use S2000-US-7-Supercharger as a base and then import the injector flow & dead times from S2000-US-8-ID1000.
S2000443
Re: Base map for S2000 with Rotrex kit, Flash pro and ID1000 inj
Post by S2000443 »
Can we get an ID 1300 cc injector flow and dead times added to software or maybe you can post it here so I can add this to the supercharger calibration map you have. Thanks
