Kpro enabled shift light???
protoge91
Post by protoge91 »
Hey guys...just wondering If there is a way to enable the redline shift light to come on at any time...and if not then will an autometer shift light work ok with kpro?
2002 Acura RSX Type s USDM
2002 DSM ACURA RSX TYPE-S / K-PRO / PWJDM INTAKE / OBX V2 HEADER / HASPORT MOTOR MOUNTS / INGALLS ENGINE TORQUE DAMPER / K-TUNED BILLET SHIFTER / SCHROTH RACING HARNESS / ENERGY SUSPENSION
Re: Kpro enabled shift light???
You may be able to setup an aux input to do something like this, but it will require some custom wiring and ingenuity. An Autometer will work with K-Pro.
MarkyMark203
Post by MarkyMark203 »
I am using an Autometer light. Can you elaborate as to where the two wires go?
You will have to refer to the installation instructions that came with the shiftlight.
