Individual Cylinder Ignition Trim
iketh
Post by iketh »
I'm sacrificing fuel mileage for power because this table doesn't have a high and low. The trim needed on high cam is significantly larger than low cam. Would be a good addition for tuning.
Re: Individual Cylinder Ignition Trim
At low/medium load ignition timing makes very little difference to fuel economy.
iketh
Post by iketh »
ok but you're not taking into account change in fuel requirements... the cylinder needing most retard requires the most fuel, so the power benefits are larger than your chart implies
the purpose is to even out power and a/f ratio between each cylinder, so I think the benefits are tangible having a separate WOT table for both fuel and ignition cylinder trims
Sorry, I thought you meant ignition trim. Individual cylinder fuel trim is a percentage, so an adjustment will be correct over all load ranges. It is hard to adjust without individual lambda sensors.
I do not believe that this is true.
iketh
Post by iketh »
Hondata wrote:Individual cylinder fuel trim is a percentage
shoot you're right... how about ignition trim being a percentage too :)
No, ignition trim must be a relative trim. As a percentage it would be hard to determine what the base should be (probably not TDC).
iketh
Post by iketh »
yea it would be a value in the table
