Hondata for Foreign (Non US) ECU
rovafa2002
Post by rovafa2002 »
Hello,
I have a 98 Honda civic EX with the stock D16Y8 engine. The car its made in the US but since I live in Uruguay it comes without the OBDII port, therefore I dont know what I have.
Only thing I have is the number that appears on the ECU, which is:
37820-P2P-K01
925-300556
Is hondata applicable for this foreign ECU? I am planning on just doing the Hondata but with all stock components would that be useful? I could install a Shortram if but, but I dont think about going any further. Any recomendations?
Thanks and regards!,
Rodrigo
Re: Hondata for Foreign (Non US) ECU
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want (http://www.hondata.com/sproducts.html). I would recommend the s300.
