AEM wideband installation on Kpro3
Vitor
Post by Vitor »
Hello,
I need some help with the wiring of the AEM wideband on my Kpro3, i know that the black wire is for grounding, the red on for power and the white one to connect to the ECU, but where exactly on the ECU? Is it on the E connector space 15?
And should i run as close or open circuit?
What else should i take into consideration?
Thanks.
Re: AEM wideband installation on Kpro3
http://www.hondata.com/help/kmanager/an ... b=wideband
IF you do not want to input it directly to the K-Pro board then you can also input in to the ELD input on the ECU plugs.
http://www.hondata.com/help/kmanager/ecuconnectors.htm
