Hall Sensor Question
ej1_ex
Post by ej1_ex »
I have a quick question. I am running a hall sensor when they say ground the ground wire on the sensor is it to body ground or ecu ground?
Re: Hall Sensor Question
I think this diagram may help (from the help file).
http://www.hondata.com/help/tractioncon ... wiring.htm
The sensor ground should be the same ground as the Traction Control ground. This should be the same as the ECU ground to keep the ground loop short.
ej1_ex
Post by ej1_ex »
then I'm assuming 5v goes back to ELD/ecu
No, the +5V is a 5V power supply for the sensor. You could get this from one of the ECU VCC outputs or from an external power supply.
If the sensor allow it then +12V would work as well, and be easier.
ej1_ex
Post by ej1_ex »
Do I eliminate the stock vss?
You still need the VSS for the ECU.
