Speedometer wont read
Dondada03
Post by Dondada03 »
I am running an 07-08 Auto Ecu inna 2004 MT cl9 ukdm, i recently upgraded my gears to the RSX type S gears and Final Drive. i have realised that my speedometer doesnt read at all. can you inform to how i could solve this?
Zoro2006
Re: Speedometer wont read
Post by Zoro2006 »
Dondada03 wrote:I am running an 07-08 Auto Ecu inna 2004 MT cl9 ukdm, i recently upgraded my gears to the RSX type S gears and Final Drive. i have realised that my speedometer doesnt read at all. can you inform to how i could solve this?
it's not releated with FlashPro at all.
Check your speed sensor as it doesn't get signal from 3th gear.
Known as Vaikis_
If you swapped out 3rd gear then the speed sensor is probably too far from the teeth to read. It could also be too close, and has shaved the speed sensor down via the teeth.
