NEED HELP TO INSTALL ON WINDOWS 8
Magic
Post by Magic »
I HAVE A NEW LAPTOP AND WHEN I TRY TO INSTALL HONDATA S300 ON MY WINDOWS 8, IT GOES THROUGH THE MOTIONS, THEN SAYS ERROR
Re: NEED HELP TO INSTALL ON WINDOWS 8
What exactly is the error?
JMCFab
Post by JMCFab »
Windows 8 is a tough OS, but it may run via Compatibility mode. May want to try turning off User Account Control as well.
IMHO I would go to Windows 7 on the machine so long as there is driver support. If you have Windows 8 Pro, it's free, if you have the basic one, its $100 for a "downgrade" license which is really an upgrade license.
If you right click the setup exe and go to the compatibility tab you can set it to Windows 7 and retry the installer. I would disable any AV/security software you have temporarily for the install as well if it is blocking any of the processes.
There is a pattern:
Windows 3.1 - great
Windows 95 - bad
Windows 98 - great
Windows Me - bad
Windows XP - great
Windows Vista - bad
Windows 7 - great
Windows 8..........take a wild guess lol
Post up how you make out.
Magic
Post by Magic »
I hope I got the screen shot. now this is coming up for an error
Delete the directory it is trying to install into and then reboot and install.
Magic
Post by Magic »
Spunkster wrote:Delete the directory it is trying to install into and then reboot and install.
ok I did that, and it let me install but as soon as I hit the finish button it said error agian
JMCFab
Post by JMCFab »
Did it launch once you closed out of the error message and tried to load it from the Start Menu/Desktop Icon?
Remove any antivirus software as it is interfering with the executable. Then reinstall Smanager.
LDForget
Post by LDForget »
i tried installing it on a windows 8 AMD processor laptop before and it failed. Apparently only Intel processors are supported. Make sure your laptop has an intel processor.
Magic
Post by Magic »
JMCFab wrote:Did it launch once you closed out of the error message and tried to load it from the Start Menu/Desktop Icon?
it did not. I tried and gave me same error code
Magic
Post by Magic »
LDForget wrote:i tried installing it on a windows 8 AMD processor laptop before and it failed. Apparently only Intel processors are supported. Make sure your laptop has an intel processor.
im not 100 percent super savy on computers but this says its an intel inside core i7
Magic
Post by Magic »
Spunkster wrote:Remove any antivirus software as it is interfering with the executable. Then reinstall Smanager.
I will remove any antivirus and then delete the smanager and then reboot and try to reinstall. thanks I will get back in a few
Magic
Post by Magic »
smh.. still the same thing... same error code 0
You must still have internet protection or antivirus software running.
Magic
Post by Magic »
Spunkster wrote:You must still have internet protection or antivirus software running.
nope. I have had multiple ppl come by and make sure all is deleted. still the same error code!!
DOES ANYONE HAVE S300 ON THERE WINDOWS 8????
