Random CEL - 3K Rev Limit
boosted k20
Post by boosted k20 »
2007 SI just got tuned and everything was running good but after driving around the car for a few minutes it would throw a CEL and the rev limit would be stuck at 3K. I didnt check to see what the code was but i heard that i need to do the following: Can someone confirm... will not get a chance to get to the car until later on this week
Guys if you are moving to a MAF based Hybrid cal and for some reason your car's CEL, VSA and triangle with the (!) shows up. In addition to those lights it wont pass 3k rpm.
Go to FlashPro Manager and on your calibration settings, under Misc uncheck the "Mass or volume circuit range performance problem enabled (P0101)"
Re: Random CEL - 3K Rev Limit
first you need to see what the error code is
boosted k20
FYI disabling "Mass or volume circuit range performance problem enabled (P0101)" fixed the problem
