flex fuel sensor help
cfdproductions
Post by cfdproductions »
so i have a s300 white board with a gm flex fuel sensor in the return line ... i have power and ground hooked up and the signal wire running to the analog 0 pin from my ecu harness with 2.4k ohm resistor in line ... what else do i need to do to get thîs to work as im not getting a reading in my sensors tab while data logging ... is there a voltage that i can test with a multimeter ?
Re: flex fuel sensor help
What sensor did you use? How have you wired it in? What calibration have you used?
