fault with flashpro firmware
schoeung
Post by schoeung »
hi, im having a problem uploading a cal. Everytime i try it says;
"The last flashpro upload failed,failure information : code 0 step 0 adress 0x00000, explanation: there is a fault with the flashpro firmware"
as of yesturday, i have the flashpro manager 1.9 and when i plugged in my flashpro, it updated the firmware. Now i can't up load and cals. Any help or info please??
Re: fault with flashpro firmware
Please tell me what your serial number is, then use the 'send support information to hondata' menu item.
schoeung
Post by schoeung »
Thanks for the reply, but it works now. :)
R3KONT3K
Post by R3KONT3K »
I now have this problem also - Just after updating to 2.6.8 - Now can't Upload to it same error statement after trying
flashpro upload failed Code 0 Step 0 Address 0x000000
R3KONT3K
Post by R3KONT3K »
schoeung wrote: Wed Jun 18, 2014 7:05 pm hi, im having a problem uploading a cal. Everytime i try it says;
What did You do to Fix It??? I having Same Issue
R3KONT3K
Post by R3KONT3K »
my Serial # is : FP-2012Si-113518
FlashPro Mngr: 2.6.8.0
2015 Civic Si Coupe
can't upload even when connected via laptop-flashpro-obdII- still gives error: flashpro upload failed Code 0 Step 0 Address 0x000000 Reason: There is a Fault with FlashPro Hardware
And Yes: - I have Used the "send support information to Hondata option" a couple of times - w/ no response
Emailing support now with all the issues I am noticing so far:
RPMS increased is intermittent: sometimes can go to 7600 from 2nd to 3rd gear sometimes it cuts fuel at 7k just like its stock - like every other run to redline:
Launch Control does not work at all - cancel button does not show me LC Limit - clutch depressed in first gear - ebrake - TC off - CC off - in every different combination does not work - flashed a couple times - does not work.
The 'send support information to Hondata' is only monitored when we request it. It says this when you send it.
There is a fault with your FlashPro hardware. Email support@hondata.com with you serial number, name, address and phone and we will issue a RMA.
R3KONT3K
Post by R3KONT3K »
I e-mailed you guys this morning with all the info - thanks for all the help!
johnmc83
Post by johnmc83 »
As of today I am experiencing the exact same problem and error message when I updated FP manager software. I cannot load a cal to FP unit but it will datalog. Message is same...
The last Flashpro update failed.
Failure information : Code 0 Step 0 Address 0x000000
Explanation: There is a fault with the Flashpro hardware.
Serial number is FP-2012Si-113381
Please advise
9thGencivic
Post by 9thGencivic »
I am having this same issue. Just updated my flashpro for the September update now I can’t download my calibrations.
Soyer
Post by Soyer »
Hi guys,
I'm having this issue (flashpro upload failed Code 0 Step 0 Address 0x000000) since I updated the flashpro firmware.
S/N: FP-2012Si-114432
Already sent feedback by flashpro manager.
Thanks,
Soyer wrote: Tue Mar 31, 2020 1:32 pm Hi guys,
Thanks,
From Help, About, what version of software are you using?
