d17 running issues with k-pro
MUGENVX9
Post by MUGENVX9 »
ive rebuilt my d17 i have the k-pro and the motor was tuned with k-pro the car was running before the rebuild i have the car back together and the only thing ive changed on the car is the compression i went from a 9.0:1 to a 9.5:1 comp ratio now when i start the car it will run for 10-30 sec then shut off like you turned the key off the only other thing that was changed in the rebuild was the version of k-pro to the latest and greatest form hondata so they say ... i have no cel ive check all my sensors the k-pro reads and sensor work ... i have no clue what the hell is going on any one else have this problem after there update ? here is a video of the motor
https://www.youtube.com/watch?v=984Ek4e460Y
also data log
MUGENVX9
k-pro
Post by MUGENVX9 »
my car was tuned on 3.0.3 now that i got the update 3.3.3 my car dont run so yes i do belive the people at hondata are human and they do make mistakes no matter what they tell us ... i have a d17 in my car running the k-pro the car now runs for 30sec then shuts off i have tested every last possible thing i can and i come to the fact that theres something wrong in the k-pro was it the update ? and i would like to check for my self with the version my car was tuned on ? only thing hondata add was crap for the v3 k-pro i have a v2 that stuff does me no good so yes i should be able to go back to the version i was running
Re: d17 running issues with k-pro
