TC retard table
prote5
TC retard table
Post by prote5 »
Hi, i recently installed TC on civic Si 2009 and can't find TC timing retard table on software. Thanks for your help.
Re: TC retard table
'Options' menu, 'Show Advanced Parameters'. The select from the Calibration window.
prote5
Re: TC retard table
Post by prote5 »
Ok, another question... voltage offset should be the same on both devices? For example on my TC output offset is set to 1 and on flashpro is set to 0. TC is connected to A23 pin (ELD) in flashpro.
Re: TC retard table
The two settings are different. In the 'Traction Control' settings window, the 1V 'Output Offset' refers to the 0% slip level. The voltage offset is 0V.
In FlashPro parameters, the voltage offset is to compensate for any ground differences between the Traction Control unit and the ECU. Ideally this is 0V, otherwise it indicates a wiring problem.
When the ECU sees any voltage from 0V to 1V, slip is calculated at 0%. At 1V, slip is 10% per volt. eg 2.5V input = 15% slip. This was done to stop minor voltage fluctuations from showing a wheel slip.
prote5
Re: TC retard table
Post by prote5 »
Thanks for your support.. I will keep you informed
