AN1 AN2 R2,R3 and C42 question
seelback
Post by seelback »
was wanting to know what 0.1uF capacitor you recommend for the C42? Is the 1N4148 diodes nescessary for the R2,R3 or do you just recommend putting them in? Thank You!!!
Re: AN1 AN2 R2,R3 and C42 question
Analog input 1: http://www.hondata.com/help/smanager/an ... sub=analog
Analog input 2: http://www.hondata.com/help/smanager/an ... sub=analog
You must use the specified capacitor.
You can either remove the resisors, or replace them with diodes, it is up to you.
seelback
Post by seelback »
I read the info in your help files. There's multiple brands of capacitors you've specified and wondered if you preferred any of them. Same with the diodes, do you prefer to have the diodes, is there any benefits by adding the diodes?
seelback
Post by seelback »
got it to work. got the capacitor and diodes from radioshack. you guys need to specify which way to put the diodes on r2 and r3, had to cut them out and then analog 2 worked fine.
