S300 PLX Wideband Digital Sensor Overlay
Harlekin
Post by Harlekin »
I have a problem getting the digital input from the PLX Wideband working with the sensor overlay and I don´t know where the problem hides.
Can anyone help me out?
As of now, I connected the PLX TX output to the S300 board.
Then I added a second display gauge, using the data from Input DI0.
To check if it works correctly, I disconnected the analog input from the PLX -> digital input works.
At "Sensor, DI0" I entered "Digital Lambda" and a range of 10-20.
At "Setting, Sensor Overlay" I selected DI0 (Digital Lambda).
But it won´t work. SManager still uses the analog AF Input for sensor overlay.
What am I doing wrong?
seelback
Re: S300 PLX Wideband Digital Sensor Overlay
Post by seelback »
what is sensor overlay?
You have not posted your calibration or a datalog showing the problem.
Harlekin
Post by Harlekin »
What datalog should I possibly post here? I´ve explained the problem, what´s a calibration got to do with it?
I just want the digital wideband input connected at "DI0" to work as the sensor overlay.
AREA876
Post by AREA876 »
Press shift+F7 to get sensor overlay table
Harlekin
Post by Harlekin »
AREA876 wrote:Press shift+F7 to get sensor overlay table
HEAD@TABLE
It´s always the smallest things that trouble most. Thanks bunch, that did the trick
