'Error' communicating with KManager
rmthio
Post by rmthio »
Hi there, my K Pro had been running fine until a few months ago the CEL started to lights up occasionally. But recently, it has lights up permanently (along with 4k rpm limit).
I tried plugging it onto the KManager and it shows 'Error' instead of 'Online'. I then tried with another K Pro ECU in the workshop and it works fine ('Online')
Any suggestion what might cause this? Would really appreciate any help, thanks.
Re: 'Error' communicating with KManager
What is the serial number that is on the K-Pro board inside the ECU? What shows up in the Windows Device manager when you plug in the USB?
rmthio
Post by rmthio »
Thanks for your reply.
Windows detected that there was a Device connected on the USB, but it shows 'Error' on the KManager.
Serial # is 10215.
I was told that I should try to re-chip the Hondata on a PRB ECU as it is generally more robust, but will this work with K Pro III?
Please tell me exactly what shows up in the Windows Device Manager when you plug in the USB.
