Help with initial setup for modified vtec engine.
hknobel
Post by hknobel »
How do I set the S300 so that the vtec is actuated at 6000 rpm and stays on until redline. This is a highly modified frankenstein engine in an SCCA D modified Solo2 car.
Harold Knobel
Re: Help with initial setup for modified vtec engine.
Disabling VTEC window does not mean disabling VTEC. IT means that the VTEC will activate at the same RPM no matter what.
hknobel
Post by hknobel »
OK, thanks. The info about the s300 certainly does not read that way. It says setting the high and low the same disable vtec.
Harold
